Crank pulley is kicking my ass
Remeber when I blew the engine? Well when the dealer replaced it, I had them throw the ASP pelley from the other one on so I would have to do it myself. Well GOD FREAKING ZILLA and his 1000ftlb impact wrench must have put it back on. I've broken 3 stap wrenchs and stll can't get the thing to budge. My impact doesn't have the ***** to break it. The main problem is the pulley moving. Is'nt there someplace I can access to lock up the flywheel? I think there is a tol for it, but not sure. I'm not gonna turn this into a 3 day prgect because of a pulley and I'm to damn stubborn at this point to put it back together and let a shop do it just to break it all back down again. Any sure fire suggestions?
Try dropping the starter and put a wrench on one of the converter bolts so it will hold against the bell housing when the engine trys to move. Works on the old small blocks, should work on this one.....Mike
Originally Posted by LS1csherm
try heating the bolt head it's self - then replace it when you get it out
That will expand it. Besides, there is really no way to get to it other than the bolt head.
Man that is pretty crappy. If I was close to my air tools I bring over my 500ft-lbs impact and try to get it out.
Can ya borrow a larger impact from someone or ya may have to go on a tool binge like I did recently at Sears. I scooped up all sorts of stuff...1/2" drive Tq Wrench, Metric combo wrenches, U-joints, etc. Everything was on sale around here.
