Crank pulley issues
Old Apr 17, 2006 | 01:37 PM
thunder550's Avatar
High on diesel fumes
Default Crank pulley issues
Went to take my crank pulley off last night, and the bolt was loose, and the pulley won't come off with a 3-jaw puller. I tighten the crap out of the puller until the center bolt starts to bend, and the pulley won't budge. Any ideas on how to get it off? Does this mean I spun the crank pulley? I have a pinning kit on order from Manguson for the 6.0.
Old Apr 17, 2006 | 01:43 PM
krambo's Avatar
Why are you taking the pulley off?
Old Apr 17, 2006 | 01:44 PM
thunder550's Avatar
Cause the engine is coming out of the truck, then the cam is coming out of the engine.
Old Apr 17, 2006 | 02:11 PM
KySilverado's Avatar
Sounds like you spun it and now its gauled to the crank. Put some heat to it would be my thought.
Old Apr 17, 2006 | 02:32 PM
white1's Avatar
Old Apr 17, 2006 | 02:40 PM
jmproductions's Avatar
Heat and get a better puller. I sheared a bolt off on one of the jaws of my puller getting it off, those suckers are reallly on there.
Old Apr 17, 2006 | 02:54 PM
white1's Avatar
How many miles are on there? I did one last Sat and it was a pain in the ***, then I did one this past Fri with about 20k miles on it and it was smooth and easy the whole way. The one last Sat took a little heat to get it off.
Old Apr 17, 2006 | 04:42 PM
thunder550's Avatar
The engine has 120K miles, but I had the crank pulley off around 100K for a cam swap. I guess I didn't get the bolt tight enough or something.
Old Apr 17, 2006 | 04:48 PM
TXsilverado's Avatar
exactly what does spinning the pulley mean?
Old Apr 17, 2006 | 05:52 PM
The crank pulley is not pinned/keyed on the cranks in the LSx style engines. It is a press fit. Sometimes, mostly SC'd applications, the pully will spin on the crank.
