crank gear puller?
I am going to install a double roller timing chain and ported oil pump. C-motorsports said I will need a crank gear puller for the oil pump removal.
Any ideas on where to get one? Is it something I can rent as I won't use it everyday
Thanks
Thanks
Thanks
Thanks
Bent the center bolt in the puller. We even heated the pulley up, beat on it, etc.
Luckily, we were able to borrow a heavier duty puller from a friend (probably $150 if we bought it new) and it pulled it right off within about 10 seconds.
InsaneDomestics
Jul 27, 2015 02:42 PM
GreyChevy
Jul 7, 2015 08:57 PM
