Cooling system - Stock thermo of 212* and Burping...
Old Jul 28, 2003 | 12:00 PM
Hit Man X's Avatar
Default Cooling system - Stock thermo of 212* and Burping...
Well I noticed that on the back of my stock thermo it has been stamped with a 100*C or 212*F! Is that where that thing was opening at?
How can I besure my cooling system is fully burped? I filled the radiator after the thermostat swap. Then filled the **** out of the overflow bottle. Let it idle for ~1 min and it didn't seem to take in any more coolant...ANY IDEAS?
Thanks!
Old Jul 28, 2003 | 03:55 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Cooling system - Stock thermo of 212* and Burping...
I think the procedure for filling is to fill the coolant to the full line and then rev the engine from idle to like 3000rpm and hold it for a few seconds. Repeat the idle to 3000rpm deal a few times and then check the coolant and fill as necessary. Keep doing that until you don't have to put any more coolant in. I could look it up but, I'm feeling lazy right now. :p That's about what I did when I had to refill my cooling system.
Oh yeah, I think you need to leave the coolant tank cap on loose while doing that.
I guess I'll look it up since I don't want to be responsible if your engine blows up. I might not do it until later though. :p
Old Jul 28, 2003 | 04:00 PM
Hit Man X's Avatar
I've driven it around quite a bit and that resivor stays full...does that mean the cooling system is full?
I feel like such a moron right now.
thunder550
Oct 8, 2015 04:53 PM
MS3Z
Jul 30, 2015 06:17 PM
lxcoupe
Jul 21, 2015 02:12 AM
4B11T
Jul 13, 2015 03:48 PM
