coolant throttle body bypass
Old Jan 16, 2005 | 10:32 PM
Riceconvert5.3's Avatar
Default coolant throttle body bypass
What are y ou guys talking about when you mention a bypass of the throttle body from the coolant
Old Jan 16, 2005 | 10:57 PM
SnakeOiler's Avatar
Coolant flows through the bottom of the throttle body. Take a look. You will see a coolant hose on each side. Take them off and hook them together with a hose coupler and you have then made the coolant bypass the throttle body.
Old Jan 16, 2005 | 10:59 PM
Faze2183's Avatar
any power gains??? whats the point of it???
Old Jan 16, 2005 | 11:01 PM
RyanA's Avatar
The point of it is to keep the throttle body from freezing. Unless you live in Alaska or Antartica, you don't really need it. Most people claim to fell a difference.
Ryan
Old Jan 16, 2005 | 11:03 PM
SnakeOiler's Avatar
Doing the bypass keeps the intake charge cooler, thus denser, thus more power. As little as that tube is, not much coolant is flowing through there - I don't know if it's worth it. I have no number to back that up, maybe someone else does.
I haven't done it on my truck, but I did do it on my Z. The LT1 has a great deal of coolant flowing through its throttle body.
Whistlin00's Avatar
14 Second Truck Club
It just makes the air going in colder
Old Jan 16, 2005 | 11:06 PM
user 108208932024's Avatar
Banned
I did it to my truck didn't feel any extra power but it cant hurt. It defintly kept the TB much much cooler. I live in Florida so freezing isn't a problem. I didn't couple my hose because there is enough ro run from the engine to the radiator.
moregrip's Avatar
what a rush!
I did the mod, don't know what it did.
Old Jan 17, 2005 | 12:19 PM
nightmarechevy's Avatar
I did it and it does keep it cooler which is good here in TX. I feel that it may have helped a LITTLE but nothing very big. I guess every little bit helps though. I found these dyno results if you want to check them out.
http://www.bmrfabrication.com/tb-dyno.htm
Old Jan 17, 2005 | 12:26 PM
thanx I guess if it wont hurt anything then Ill try it and I guess it does make sense that you would want cooler air in the tb.
