converting to e85???
Old Jul 14, 2008 | 11:00 AM
jkwalkercchs's Avatar
Default converting to e85???
what all would have to be done to an 04 silverado to run on flex fuel???
injectors
tune
and what else
Old Jul 14, 2008 | 11:15 AM
kbracing96's Avatar
Thats about it, but since your truck in not flex fuel, to get max gains from it, you would need to delicate the tune and JUST run E85. A tune that runs both gas and E85 gives up something on both fuels.
Old Jul 15, 2008 | 10:13 PM
bigredexpress99's Avatar
That and the components of the fuel system are different. . . all stainless lines....special o-rings..fuel pump....
Old Jul 17, 2008 | 10:50 PM
HotRodV6's Avatar
SyTy Speed Shop
yeah and if your going to run E85 exclusively, you need to bump up the compression to take advantage of the octane of E85 and get more bang for your buck.
Old Jul 19, 2008 | 12:46 PM
L7 Sierra's Avatar
To run on E85 you need to move your fuel tables up a 1/3rd, and tune from there. Also I would advance the timing out to roughly 32 degrees to take advantage the high octane rating of E85. E-85 is racing gas at the pump it can support up to 14-1 compression. Also according to a car craft article I read E85 is very forgiving about running lean to much timing, and some other engine killers. Also its a excellent highboost fuel since you can keep timing high and gain quite a bit extra Hp for FREE.
But if you switch to E85 your stuck with it till you re-tune for gas.
Is your truck one of the flex fuel trucks? If it is then your job is much easier, but flex tuning can not do as good as a single fuel tune.
Old Jul 20, 2008 | 04:27 PM
sprayed8's Avatar
i am curious about which which vehicles are flex fuel. my 02 was never advertized as flex fuel but inside the fuel door there is a warning not to use any additives on E85 fuels. so does this mean it was made to run E85?
Go5.3tt06
25
Sep 4, 2016 10:25 AM
GMCtrk
Jan 27, 2016 06:47 PM
ClintBeastwood
11
Sep 13, 2015 11:49 PM
jtphelps289
Sep 11, 2015 06:37 PM
06 4.8
Sep 11, 2015 10:36 AM
