converter ?
Old Mar 9, 2004 | 03:29 PM
02chevyracing's Avatar
14 Second Truck Club
Default converter ?
will a converter off a ls1 f-body work on our trucks they both have the same trany?
Old Mar 9, 2004 | 04:17 PM
Flyer's Avatar
Yes ... Don't know how it would act though .. as far as driving characteristics.
Old Mar 9, 2004 | 04:51 PM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
I believe the Vigilante's fit all 60E's...trucks...f-bods...etc...it's a 9.5" verter if I remember correctly
I have the 3200 and it made my truck a lot more fun to drive. It is kind of loose which can get a little annoying in slow traffic. I might switch to something a little tighter this summer or whenever the tranny blows (soon)
Old Mar 9, 2004 | 04:56 PM
Banned
what size are the Fbody stalls? can't be to terribly much different than the truck ones...jump on one of the GPs going on and get a good stall with a warranty and all that.
Old Mar 9, 2004 | 11:58 PM
ThunderZ28's Avatar
12 Second Club
hey chingy you know you can have Allen tighten it up for you when he tunes it?
Old Mar 10, 2004 | 12:12 AM
Really? I did not know that. I can't wait until next week then
Old Mar 10, 2004 | 12:37 AM
FLASH's Avatar
from what i have heard the converter will fit but the inside is different on the converter for ls1s and our trucks
Old Mar 10, 2004 | 12:38 AM
ThunderZ28's Avatar
12 Second Club
Old Mar 10, 2004 | 12:44 AM
Well...when I went to pick up my truck after the vig install...the guy said he had to put a washer or something in there because the verter would not sit directly against the tranny...there was some play that, had he not put the washer or whatever, would've caused a shudder while I drive.
Hope that helps a little
Old Mar 10, 2004 | 09:41 AM
gonzo 6.2's Avatar
According to Mike at yank the Ls1 converters have a standard lockup clutch because there are a on/off lockup And the trucks have a pulse withd modulated applied clutch which require a carbon fiber lock up clutch disc.You could use a LS1 but you would want to change you VB to a on/off apply or you would burn up the Ls1 converter.
jscherbs
Mar 24, 2017 07:20 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
TAPyvehc93
Jan 8, 2016 10:47 AM
jtphelps289
Sep 11, 2015 06:37 PM
06 4.8
Sep 11, 2015 10:36 AM
