Compression ratio and octane
Old Dec 30, 2008 | 05:02 PM
GMCtrk's Avatar
Default Compression ratio and octane
I'm seriously considering putting 243 heads on my 6.0 turning it into an iron LS2. Should be around 11:1 compression. The only reason I haven't done this so far is that in the summer's I tow and go camping out in the boonines - no good gas. I was thinking to have a pcm with a 93 tune and then have another one I can swap in to run 87 on the occasions that I go camping. Will the motor be okay on 87 with lowered timing? I know it will be down on power, but I dont care. I've read that the TBSS runs just fine on 87. Thanks!
Old Dec 30, 2008 | 05:17 PM
GMCtrk's Avatar
Can anyone confirm or deny that the 243 heads on the newer 4.8 and 5.3 use 2"/1.55" valves?
Old Dec 30, 2008 | 09:18 PM
Fireman31's Avatar
low octane fuel and high compression = knock, ping, detonation, power loss, and less efficiency...
Instead of having 2 PCMs, you'd be better off just putting 87 in it if you had to(with the 93 tune). The detonation/knock created by the lower octane fuel will cause the PCM to retard timing, which will roll it into the low octane tables anyway.....
Old Dec 30, 2008 | 09:28 PM
GMCtrk's Avatar
I guess I'll have to ask Charlie about this.
If the TBSS can run just fine on 87 I see no reason why I couldn't.
Old Dec 31, 2008 | 12:26 PM
GMCtrk's Avatar
Here's the advice I got from Predator-Z
8.47 DCR which is fine on 11.0:1 SCR
My advice is to run 1 step colder plugs like TR6 gapped at .040>.045 (they come .035 from factory)
The colder plug will reduce chances of detonation.
zblee
Nov 11, 2015 12:41 AM
turbo6c3
Oct 5, 2015 06:11 PM
Velocity1
Oct 2, 2015 08:01 AM
old motorhead
Sep 29, 2015 08:22 PM
