compression check?
Old Mar 10, 2003 | 10:44 PM
RED2K's Avatar
Default compression check?
What should each cylinder read when i do this?
Old Mar 10, 2003 | 11:14 PM
Default Re: compression check?
You will lose some static compression with a cam change. With the increase in lift and duration the engine can't make as much cylinder pressure.You do get a side benifit that your octane requirements for the engine are reduced.Check for big differences in compression between cylinders if the high and low cylinders are within 10 to 15 percent you are ok.
Old Mar 13, 2003 | 07:01 PM
RED2K's Avatar
ttt
Old Mar 13, 2003 | 07:15 PM
really slow truck's Avatar
like he said they should all be somewhere within around 10-15% of each other. i cant remember what mine read when i checked it a while back tho <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 13, 2003 | 07:39 PM
BigTex's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by really slow truck:
<strong> like he said they should all be somewhere within around 10-15% of each other. i cant remember what mine read when i checked it a while back tho <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What does yours read right now? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 13, 2003 | 08:10 PM
well, i screwed in the pressure gauage, turned the engine over a few times to see what it read for good ol' red2k... kept getting readings of zero <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
but then i was thinkin, doesnt it work better when the head is attached to the block? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ March 13, 2003, 08:15 PM: Message edited by: really slow truck ]</small>
Old Mar 13, 2003 | 10:56 PM
RED2K's Avatar
REally slow= you ***** <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .. Man that is what i exactly what i am wanting to find out. What psi should they read?
Old Mar 14, 2003 | 11:20 AM
what are yours reading?
Old Mar 14, 2003 | 01:06 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
I would have to guess somewhere around 125-to-150psi to be the norm. I think that as long as it is over 100psi that it is within GM's specs.
Old Mar 14, 2003 | 01:18 PM
L82gofast's Avatar
Yep, Neil is right. The GM spec in the service manual just says 100psi - minimum.
walledition
Feb 24, 2026 03:27 PM
zblee
Nov 11, 2015 12:41 AM
Tydriver
45
Oct 23, 2015 09:19 PM
Boyes50
Sep 8, 2015 12:06 PM
bisqikss
Sep 8, 2015 03:35 AM
