Complete 6.0 engine specs
Old Mar 13, 2005 | 11:03 PM
99Silver6.0's Avatar
Default Complete 6.0 engine specs
Alrighty. Im trying to figure some things out. But I cant seem to find some solid spec numbers to even get a correct stock compression ratio with a calculator. Does anybody know what the specs are??
Cylinder Bore Size 4.00
Piston Stroke Length 3.62
Head Gasket Bore Diameter 4.135
Compressed Head Gasket Thickness .052
Combustion Chamber Volume In CCs 71.06
Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') -8
Piston Deck Clearance Negative If ABOVE Deck (Use '-') .006
Are these numbers right???????????
Old Mar 14, 2005 | 12:02 AM
BigTex's Avatar
Stock gasket bore is 4.04"
The rest are very close.
Bumpers
Aug 4, 2024 09:44 PM
OHsixLS3
Dec 27, 2016 09:30 AM
OLD BULL
Aug 1, 2015 05:00 PM
steves86ta
Jul 28, 2015 10:21 AM
NuckenFuts
Jul 9, 2015 08:45 AM
