Comp Cams LSR 265LR HR12 Cam?
Old Dec 28, 2009 | 03:15 AM
Brutal_LS1's Avatar
Question Comp Cams LSR 265LR HR12 Cam?
Does anyone have any info, or have used a cam in their truck with a similar grind? Comps site claims, very strong torque and excellent response and that it also works best in heavy, low RPM vehicles. I have an Avalanche and I'd say it's pretty heavy and it's not a high RPM screamer. Anyways I'm thinking about buying it. The specs are 215/223 .604/.610 112LSA, what do you guys think?
Old Dec 28, 2009 | 06:25 AM
SweetS10V8's Avatar
I love cams with low duration and high lift. It will have good manners and make lots of power and torque. And if you ever do a head upgrade, this will still work great.
Old Dec 28, 2009 | 11:58 AM
Avalanche2002's Avatar
It will be OK as long as you are prepared to do the proper tuning to go along with the new cam. It will have more power in the higher rpm range than off the line grunt. Your TT3000 should help with that issue considerably. I've got a Comp 216/224-.551/.551-115 cam (same cam as the Vinci Trucker) going into my Avalanche today.
Old Dec 29, 2009 | 12:03 AM
Brutal_LS1's Avatar
I wonder if I could get away with buying a nelson performance PCM and just plug that in once I got the cam installed?
Old Dec 29, 2009 | 12:08 AM
GMCtrk's Avatar
I think that would be a great cam for your avalance.
Old Dec 29, 2009 | 12:13 AM
Brutal_LS1's Avatar
I definitely want to do heads later too. I just want a nice cam that I won't have to worry about changing for a while that while compliment a nice set of heads.
Old Dec 29, 2009 | 09:35 AM
You'll likely get a crank position sensor light if you buy a new pcm. Then you'll have to have someone do a crank relearn; the dealer will charge around $90 to do that. You can get around doing this if you send Nelson your pcm and let them put the tune in it but that means you have to do without your truck for a while.
Old Dec 29, 2009 | 04:53 PM
silveradokidd_4518's Avatar
thats why i keep an extra PCM lying around...
and that cam will be good in your truck... nothing too wild
Old Dec 30, 2009 | 12:02 AM
Brutal_LS1's Avatar
Couldn't I buy another PCM from Nelson that is tuned for the new cam and my other parts and just swap it as soon as I have the cam installed? I kinda want to just keep my stock computer as backup.
Old Dec 30, 2009 | 12:09 AM
Brutal_LS1's Avatar
Yeah I like having a backup too.
Good. Do you know of any other cams that would produce good torque down low?
