comp cam xer 6.0
Old Aug 19, 2006 | 11:24 PM
sroach20's Avatar
Default comp cam xer 6.0
decided to go with a 6.0 since i got a good deal on a new block. im going to keep it stock stroke and bore for now, but put forged pistons in case i wanted to run a little boost. im using some 241 heads since they were pretty cheap. im going to get an xer 224/224 .581/.581 114+4 from speed engineering since they have a great price. my question is can the patriot springs hold up to the high lift and aggresive lobes of the xer? also does anyone have a an xer in a 6.0 with the same grind or close to it?
Old Aug 20, 2006 | 08:04 AM
Bowtie70SS's Avatar
I have a custom grind XER .640 lift 227 duration with the patriot springs. About 1000 miles now so far so good, it is a little noisy though, almost like a old Big block Chevy with a solid lift cam. Later
Dave
Old Aug 20, 2006 | 08:16 AM
.T.'s Avatar
.T.
I have dual rate springs w/mine. Dunno about the Pats but at .581, if they're rated at .600 and you run an xer I don't see why there'd be any prob. Like Bowtie said above, it may be noisy but I switched to 10/30 Mobil1 and don't hear any noise anymore.
Old Aug 20, 2006 | 09:21 AM
litreddevil's Avatar
Banned
Thunder Has Some Of The Same Cams
GrooveCityZ71
Aug 31, 2015 12:05 PM
OLD BULL
Aug 1, 2015 05:00 PM
low2001gmc
Jul 23, 2015 05:10 PM
projectnightcrawler
Jul 19, 2015 11:30 PM
4B11T
Jul 13, 2015 03:48 PM
