Comp 918
Old Jan 18, 2006 | 08:00 AM
virgils4.85spd's Avatar
Default Comp 918
I saw in a post in here that the comp springs ill be needing for the tr 224 cam are only good for 15000mi! Is this true?? If it is, which other springs should i get? I hope not but who knows. Please respond!!
Thanks,
Derek
Old Jan 18, 2006 | 08:40 AM
hellbents10's Avatar
LS1Tech Sponsor
918's will last a lot longer then that with that cam.
Old Jan 18, 2006 | 09:16 AM
white1's Avatar
Good, I had just heard (read) this too. I guess they recomend changing every 15000 miles with a fast ramp cam with close to .600 lift?? How will I be able to tell when mine need changing?
Old Jan 18, 2006 | 10:30 AM
budhayes3's Avatar
PT's Slowest Truck
I'd like as much info on this as possible also. I did a bunch of searching at LS1Tech a while back, and the concensus was that annual valve spring replacement was an expected maintenance for high lift, fast ramp cams.
Old Jan 18, 2006 | 10:59 AM
white1's Avatar
Wonder whats considered high lift?
Old Jan 18, 2006 | 12:54 PM
yeah this would be nice to know!
Old Jan 18, 2006 | 01:02 PM
ThunderZ28's Avatar
12 Second Club
the 224 is a fast ramp cam..
I just had mine checked and they where still with in there limits..
have about 25,000 miles on them..
Old Jan 19, 2006 | 08:32 PM
budhayes3's Avatar
PT's Slowest Truck
25K with a TR224 sounds pretty good to me....anybody else have any cam spec/mileage experience with the 918's?
Old Jan 19, 2006 | 08:36 PM
99Silver6.0's Avatar
Id run a dual Crane spring before I played with 918's.
98TAauto's Avatar
bud, i think the biggest rool is in how hard you drive the truck. If you race every week, then of coarse the springs will weaken faster. I had 918's on my car for 2 years and about 20k miles... but i swapped those for duals now.
I think some have had as much as 30-40k on them, but it would be safe to swap them with anywhere from 15-25k on them. They might last forever, or one could go at 20k and cost you 4-6k in damage
