Cometic Head Gaskets 5.3l
Old Dec 9, 2010 | 08:58 PM
Bigschwerm's Avatar
Default Cometic Head Gaskets 5.3l
Im going to be installing a set of P/P 243 heads milled .040 on my stock 5.3l bottom end. Cam is a Lunati voodoo 222/228 .567/.567 113 + 4
I want to run a set of thin Cometic head gaskets...what part number do i need? The smallest bore size i seen was a 3.910" is that ok to run a standard 5.3l bore?
Old Dec 10, 2010 | 07:28 AM
Bigschwerm's Avatar
To the Top
Old Dec 10, 2010 | 03:13 PM
Bigschwerm's Avatar
Anyone?
Old Dec 11, 2010 | 09:24 AM
Bigschwerm's Avatar
Someone must have installed some on a 5.3........
Old Dec 11, 2010 | 05:43 PM
fastrt's Avatar
11 Second Truck Club
I dont know part numbers, but a cometic .040 3.910 bore is what I used. worked good. You can call them and they will make a 3.78 bore gasket. but I wouldnt go lower than a .040" gasket.
Old Dec 11, 2010 | 10:30 PM
max1's Avatar
Banned
yes that is the correct gasket . your gaskets must match your heads- not ur bore. i have the same project your building..
If you milling your heads- why dont you go all the way.
- your going to run a mid lift cam- you can prob get away with .0450 or .0500 w/out any PVC issues..
Old Dec 12, 2010 | 08:33 AM
Bigschwerm's Avatar
Thanks for the input guys!
I only milled the heads .030 because they will most likely be transferred over to my LQ9 at some point down the road.
Old Dec 12, 2010 | 12:36 PM
fastrt's Avatar
good call, always think about a future mod.
thunder550
Oct 8, 2015 04:53 PM
slowlsx
Aug 13, 2015 08:28 PM
slowlsx
Aug 10, 2015 05:33 PM
BIGD4504
Jul 28, 2015 11:46 AM
