Cold weather no start
Old 12-09-2018, 09:38 AM
MikeGyver's Avatar
VATS disables the fuel.
Old 12-09-2018, 10:40 AM
woodwright's Avatar
Does it disable the fuel pump or the injectors?
Old 12-09-2018, 08:22 PM
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Injectors. Pump will still prime
Old 12-10-2018, 06:05 AM
13 Second Truck Club
trxmxzx's Avatar
Thinking outside of the box here, how good is your battery? It may crank but not have the juice to power other electronics
Old 12-10-2018, 09:18 AM
woodwright's Avatar
I was thinking about that. Seems like if it had enough juice to crank over it would be fine. Is that not right?
Old 12-10-2018, 11:28 AM
arthursc2's Avatar
if it can power the starter (100+amps) it has enough for the fuel pump and ECM who are combined ~30amp worst case scenario.
Old 12-10-2018, 04:39 PM
00pooterSS's Avatar
Not always. I've had a few cars with weak batteries crank the engine but not have enough left to fire the coils hard enough. And that will be more of an issue the colder it is. (harder to light off fuel the colder it is so you need all the spark you can get)
Does it crank over real strong? Or does it sound a little weak?
I was at AMP a few weeks back and a guy brought a 2010 truck in because it would randomly run bad after starting it. It had a weak battery and it was strong enough to crank the engine over but it was so borderline that the computer was losing crank signal during the crank. I hadn't seen that before but apparently Sam had, he went right to the issue and saw the crank signal dropping out during cranking. The guy had a little fork lift battery or something like that in there.
Old 12-10-2018, 06:52 PM
trxmxzx's Avatar
Old 12-10-2018, 09:42 PM
00pooterSS's Avatar
If you hear the fuel pump and also tried spraying starting fluid in it and it still doesn't run it must be ignition.
I'd go for battery first, then cam or crank sensor if that doesn't help.
If you have a jump box around connect it up and turn it on and fire the truck with the battery and jump box, if it fires right up you know you have a weak battery. You could also boost it from another vehicle for a few minutes before cranking it, in other words jump start it. That would help tell you too.
Old 12-10-2018, 10:43 PM
woodwright's Avatar
The first 2 morning I did jump it with my Tahoe. Still a no fire.
okieraptor
12-06-2013 06:30 PM
mred
13
01-03-2013 09:30 PM
MHSLOT12
01-22-2007 03:46 PM
91_bowtie
12-01-2006 01:40 PM
Quick Reply: Cold weather no start
