Cold start problem, what to adjust?
Old Feb 24, 2005 | 09:45 PM
moregrip's Avatar
what a rush!
Default Cold cranking problem, what to adjust?
Ok, it seems I have a cold start problem that is getting worse. What can I adjust and in what table (via HPT) to remedy this?
Sounds like I am getting alot of air and not enough gas even when I let the pressure build before starting.
Is this common, easy fix, I'm guessing it is. I'm thinking to pull a plug and see what I see
Old Feb 24, 2005 | 09:48 PM
Black Blown 02's Avatar
Do you have a fuel pressure guage to verify enough pressure at the rails?
Old Feb 24, 2005 | 09:49 PM
moregrip's Avatar
what a rush!
no I don't
Old Feb 24, 2005 | 09:53 PM
Did this problem start with some tuning you did, or just start out of nowhere?
Old Feb 24, 2005 | 09:56 PM
moregrip's Avatar
what a rush!
It has always been there since I installed the Radix tune, it has progressively gotten worse. I have done zero tuning, I have changed nothing.
It is now getting annoying and I want to get it sorted........sounds like a fuel issue to me, but that is really just a guess, although somewhat informed guess.
Old Feb 24, 2005 | 10:06 PM
I'd guess your fuel pressure is bleeding off. The 05's have the FPR in the tank right?
Old Feb 24, 2005 | 10:08 PM
moregrip's Avatar
what a rush!
yes, never touched it though
Old Feb 24, 2005 | 10:40 PM
moregrip's Avatar
what a rush!
Is it the open loop VE table?
Old Feb 24, 2005 | 11:04 PM
Flyer's Avatar
Give it a little more fuel at idle. That will help the little stumble that is all to common with the RADIX off idle too.
In the main VE table, decrease the values in the first 3 rows by 1% and see if that helps.
Old Feb 24, 2005 | 11:12 PM
moregrip's Avatar
what a rush!
is that the multiplier?
