Cold Engine Oil Pressure 19lbs
Old Dec 3, 2007 | 08:11 PM
dirt track racer 81's Avatar
Default Cold Engine Oil Pressure 19lbs
Finally got my truck running right with the new intake and its set few a few weeks..its been cold 20's at night and its prolly in the low 40s now and my oil pressure was 19lbs and fluctuating..just wondering what most peoples oil pressure is when its cold
Old Dec 3, 2007 | 08:13 PM
nightrunner's Avatar
Mr. Obvious
when cold at cruise speeds(1500-1800rpm), around 50-60 psi. stock 4.8
Old Dec 3, 2007 | 08:17 PM
mine was at idle
Old Dec 3, 2007 | 08:21 PM
Mr. Obvious
well i have never had under 40psi EVER, hot, cold, idle, WOT, doesnt matter.
Old Dec 3, 2007 | 08:22 PM
Derek @ EDO's Avatar
FormerVendor
when cold my psi is higher!
Old Dec 3, 2007 | 08:25 PM
TouchOfEvil04's Avatar
mines above 40 for sure at all times. Even cold.
Old Dec 3, 2007 | 08:49 PM
03RCLB_CHEVY's Avatar
50-60 in both of my trucks cold or hot
Old Dec 3, 2007 | 09:33 PM
joshua022's Avatar
Does it say 19lbs through you EFi-live or on the cluster gauge?? If on the cluster gauge you might wanna check it on your EFI-live to see if that is what the computer is reading, because the steppermotor in the cluster might be crapping out. (you've prolly already done this just thought I'd throw it out there)
My truck did almost that exact thing when the stepper motor went bad on mine and I had to replace the cluster..
Old Dec 3, 2007 | 09:35 PM
havent done this yet as i dont have efi live
