Cold Air Intake recommendations...?
Old May 17, 2006 | 02:33 PM
04extcab's Avatar
Default Cold Air Intake recommendations...?
Any thoughts on one air intake setup over another...? Consideration given to ease of install, performance gains, appearance, and price.
Old May 17, 2006 | 03:03 PM
three83's Avatar
I've had Volant and K&N. They were both easy to install, very similar performance gains, and very similar price. I prefer the volant because it seems the filter doesn't get as dirty as fast and the optional air scoop.
Old May 17, 2006 | 03:27 PM
goshawk23's Avatar
Truck addict
i say build one yourself with some 4" tubing and conical filter. much cheaper for the same gain. but if i had to buy one off the shelf it would probably be one of the two that three83 recommended
Old May 17, 2006 | 03:47 PM
Homemade is the cheapest way to go, but I really like the AirRaid setup. If you want the filter to be invisible look check out the Volant or SLP.
Old May 17, 2006 | 04:21 PM
Beastofa327's Avatar
I'm about to do a Ram Air setup with some house hold goods from Lowe's
Old May 17, 2006 | 04:40 PM
BigBlockChev572's Avatar
PVC and a Fernco.
Old May 17, 2006 | 06:12 PM
virgils4.85spd's Avatar
Default Build It Yourself ...
save about 100 dollars. Go to http://intakehoses.com/Merchant2/mer...gory_Code=SIT7 They have everything.
Derek
Old May 17, 2006 | 08:08 PM
BADMOFO's Avatar
Cuz I AM a BADMOFO
I have an AEM and it has been great. Real nice quality throughout.
Old May 17, 2006 | 08:18 PM
budhayes3's Avatar
PT's Slowest Truck
I've had the K&N FIPK and now the Volant with ram air. Both are easy to install, and seem to provide the same gains. If you ever plan on doing 05 e-fans with a 34" rad, I recommend that you go with the Volant as it clears the radiator without any modification, unlike the K&N, which needs to be cut/bent/etc. to clear the rad.
FWIW, from what I've read here, guys with the homemade versions seem to be seeing pretty much the same gains as the aftermarket CAI's.
silver-mod-o's Avatar
Hunt&Fisherator
I have a granetelli intake. I got it from another vendor from the internet. It was a lot cheaper than the other brands and its been a good one. Its pretty thick plascit so it worked out pretty well when I put the hole in it for my nitrous nozzle.
