Cold air intake and heat soak issues
Old Sep 28, 2009 | 01:35 PM
grey matter 04's Avatar
13 Second Truck Club
Default Cold air intake and heat soak issues
I am having a heat soak issue with my cold air intake or MAF.
IAT gets really high like 170s after driving at a redlight cycle or if i sit for 3 min or so.
They do come down to the 90s after a 2 mile drive at 60.
I think the maf is getting heat soaked because i can hold my hand on the intake pipe and its hot but doesnt burn me.
So should i get another cold air intake with a box around the filter to sheild heat OR relocate the IAT sensor?
IT A K&N INTAKE WITH CHROME AIRTUBE AND OPEN ELEMENT FILTER WITH A HEATSHIELD.
OPINIONS PLEASE!
Old Sep 28, 2009 | 02:08 PM
The problem is the intake tube being metal. The metal will hold the heat and heat up faster then the composite tube.
Old Sep 28, 2009 | 02:11 PM
i can hold my hand on the tube and it doesnt burn me
its hot but no burn
Old Sep 28, 2009 | 03:33 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Post up a pic of your setup. I'm curious to see how well the airbox is sealed off from the engine compartment. I'm guessing not very well. The plastic air tubes are better than the metal ones.
Old Sep 28, 2009 | 04:49 PM
series 77 k&n intake
Old Sep 28, 2009 | 05:02 PM
the actual intake tube is only 125 after a 15min drive and 2min of sitting still
Old Sep 28, 2009 | 05:44 PM
Okay, what I really meant is, open your hood and take a pic of your setup, so we can see how it is installed in your engine compartment.
Old Sep 28, 2009 | 06:17 PM
turbosilvi's Avatar
first-switch from metal tube to plastic
second-check MAF sensor and make sure its not damaged.
third-do you have stock headers and stock thermostat? those are contributing factors to having a hot engine bay. aftermarket headers get rid of heat quicker so you wont have an engine bay thats 150 degrees when you open the hood. and the thermostat helps keep the engine cooler, therefor the block will be cooler and that will drop under hood temps.
fourth-make sure the air box that you have seals close to the hood and snug against the inner fender and there is nothing blocking the cold air from coming up into the intake.
fifth-like aklowriderZ71 said, show us a pic of your engine bay
Old Sep 28, 2009 | 06:56 PM
broke1's Avatar
Banned
My opinion is that high IAT's do not cause any problems.Just a # that people seem to get hung up on when in reality ,99.9% of the time the #'s being high doesnt mean crap....
Maybe not the best for extracting all out HP but ill bet you dont lose 1-2 hp.
Old Sep 28, 2009 | 07:55 PM
andrew383's Avatar
traveling mod
Are you serious??? Why do you think guys run intercoolers or meth injection with FI???Granted he's n/a but its the same principal... cooler is better...
