code p0449
Old Sep 20, 2009 | 10:11 PM
jschrock's Avatar
Man you do not live in California....Get a tune and have the codes deleted and finally forget about it!
IMO
Old Sep 20, 2009 | 10:16 PM
Fastcount03's Avatar
Old Sep 20, 2009 | 10:26 PM
Go5.3tt06's Avatar
If I do tune and leave all my evpor alone. Or have to remove first? But remember Ga required to pass the emission.
Old Sep 20, 2009 | 10:30 PM
If you tune it out, you will be fine. You WILL have to take the line off of the vent solenoid so your tank can vent and it won't build up pressure.
Old Sep 21, 2009 | 08:55 AM
Go5.3tt06's Avatar
How it work? Im idiot how to do that. Because I never had before try. If you dont mind to draw and take pic what it look like. Tell me a step and step. IT should be ok?
Old Sep 21, 2009 | 04:55 PM
Go5.3tt06's Avatar
I found link for evap emission canister purge valve connector
http://auto-parts.myride.com/auto-pa...alve-connector
I couldnt find other part is EVAP vent valve solenoid which goes to under bed. Can you help me find one. I am going ahead order all and fix myself. Hope the light will go off.
Old Sep 21, 2009 | 05:08 PM
andrew383's Avatar
traveling mod
its a dealer item,and its either $125 or $150 i cant remember..
Old Sep 21, 2009 | 05:54 PM
Go5.3tt06's Avatar
Okay, that call EVAP vent valve solenoid right? Once I get it and I will post step and step with pictures. It will help guys who has problem with damn P0449
Old Sep 21, 2009 | 07:25 PM
andrew383's Avatar
traveling mod
yep thats it,there's other threads of guys haveing the same problem..Post up the part # when you get it so everybody will know..
Old Sep 22, 2009 | 08:46 PM
Go5.3tt06's Avatar
Good news. I bought (purge valve soleniod)
GM# 12581282 ACDELCO
First of all yesterday I tried to disconnect the battery for 10 mintues then reconnect. The engine light still on. So until today I bought a purge valve soleniod. So I took battery negative off. While I took off the intake cover plastic. Then replace the purge valve soleniod. Put all back together. Then reconncet the battery. Crank up and saw the engine light is gone! IT take me like 10 minutes to replace the purge! That mean I not need get evap soleniod where is behind the back gas tank? Let me know.
