Coating your cutouts?
Old Mar 21, 2006 | 09:40 AM
FarmerBeau's Avatar
Sexy Party Mod
Default Coating your cutouts?
I was wondering if anyone had done this and what they had coated it with? I dont want to go with a jett Hott coating but was wondering if they make that aluminized coating in a can that would be worth it. I know that some use BBQ pit paint but how long does that last. All in all, i dont want it to look like a rusty POS like it is now. Ill be going with an electric cutout so i want everything to look nice and neat on my new exhaust setup. Any advice or help is appreciated. Thanks.
Old Mar 21, 2006 | 10:03 AM
TurboGibbs's Avatar
You might try some of these from Eastwood. I have had good luck with header paint on headers with 1-7/8" primaries and larger. Anything smaller, no matter the cubes, and the heat doesn't get disipated as well and burns the paint off. I have tried numerous brands over the years and they all are basically the same. The prep work is very important. If your cutouts are rusted I'd highly recommend blasting them to get a rough surface for the paint to adhere to and clean them well with carb cleaner or laquer thinner before you paint. IMO bbq grill paint is the same as header paint. But back to my original thought, your cutouts are much larger than 1-7/8" so I would imagine that the header paint would hold up fairly well and recoat as needed. In most header paint instructions i've read it says to do a light coat just enough to cover and not lay it on heavy. Hope this helps.
Old Mar 21, 2006 | 11:25 AM
white1's Avatar
I used VHT exhaust paint on my last exhaust. The first time it all melted off, so when I re-did it I actually followed the directions (like where it said it had to cure, or it would burn off ) and did what it said, and it worked good. In fact when I re-did my exhaust, I painted the end of tohe tail pipe, and its still purdy. (at least when its not filthy)
Old Mar 21, 2006 | 01:34 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Beau OLD BULL knows a guy that does ceramic coating for cheap. Im going to get my y-pipe coated by him soon and he is supposedly pretty cheap too.
Old Mar 21, 2006 | 01:55 PM
white1's Avatar
So Cody, is he cheap
Old Mar 21, 2006 | 02:20 PM
TurboGibbs's Avatar
I was thinking the same thing man. I, for the first time, was going to let it slide. So his name is OLD BULL? And he will coat your pipe pretty cheap. hmm.
Old Mar 21, 2006 | 02:31 PM
1slow01Z71's Avatar
No OLD BULL knows someone that does ceramic coating in his backyard for cheap and supposedly he does really cheap cause if its cheap its got to be good right.
cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap, cheap
Old Mar 21, 2006 | 02:45 PM
white1's Avatar
Suprised you spelled cheap right.
Old Mar 21, 2006 | 02:57 PM
TurboGibbs's Avatar
That's sum funny shiat rite theer!
Old Mar 21, 2006 | 03:35 PM
FarmerBeau's Avatar
Sexy Party Mod
Damn Cody, such a smartass!
Ill get ahold of Old Bull. Did he have his turbo system done by this guy?
