Cleaned TB, Granatelli MAF, new CAI how to re-learn idle? It is way too high.
let the positive off the battery last night, drove to work 12 miles but seems to still have a high idle.
Is there a way to make the PCM re learn the idle? I dont have hp tuners.
05 rcsb 4.8 5 speed
05 rcsb 4.8 5 speed
any aftermarket MAF sensor, the pcm has to be tuned for it or it will act funny. i could be wrong but honestly your stock MAF sensor is plenty unless you are running a huge procharger/turbo. even the TVS2300 guys run a stock MAF sensor. just my .02
Let it idle for 5 mins warm without ever touching the gas. That's about all you can do. Then turn the A/C on and repeat.
Automatics, you put it in gear and put on the park brake and let it idle.
Left pos and neg off the battery all night last night.
I let it Idle for 8 to 10 minutes and cycled the AC on and off every couple minutes. She seems fine.
Only problem is driving into work if I shift to neutral and cost to a stop it will rev to 2,000 sometimes which is really annoying.
Should I just get the mail order nelson tune from nelson to clear it up.>?
As mentioned above, I'd throw the Granatelli up on ebay, as they've been known to cause more problems than their worth, such as lean codes and irratic sensor readings
