Cheapest way to build a 408?
Looking to start a build for my 2007 Chevy avalanche. My question is what is the most cost affective way of building a 408 that would be able to handle 800rwhp +. Should I get a short block from tsp or start in a different direction. Also will my stock 5.3 heads work on a 6.0?
Thanks in advance.
Thanks in advance.
Find an lq4 block, and get a 408 rotating assembly from tsp for 1600. Yeah your heads will work for a 6.0, It'll have killer compression and you won't be able to run real high lift cams. Theyll choke the 408 in stock form I'm sure, if they can even work for a 408
Can I stroke my 5.3 to a 370 or is that using a 6.0L block? Also I'm looking at a Ly6 6.0 and I'm wondering which 6.0 can handle more power the older or newer 6.0s?
