Changing rear diff fluid
Old Nov 10, 2002 | 09:54 PM
Bub's Avatar
Bub
Default Changing rear diff fluid
When and what do you use when changing diff fluid on a 2002 2500 HD. The manual gives a recommended weight but does not say if friction modifier is necessary. Can anyone help me out here.
Old Nov 10, 2002 | 10:34 PM
CashDudeHomie's Avatar
Default Re: Changing rear diff fluid
It probably has a gear meshing locker so probably not, but I am not sure, it would be best to check the manual again, it might be on another page or call the dealer but you probably don't want to wait until Tues...
Old Nov 10, 2002 | 10:36 PM
Wait I have an even better idea, go ahead and buy all of the stuff and when you get the diff cover off you should be able to see if it has clutch packs or not, they have a bunch of little springs, if it has them then you should add the friction modifier, if not you can return it. Just an idea.
<small>[ November 10, 2002, 10:37 PM: Message edited by: CashDudeHomie ]</small>
Old Nov 11, 2002 | 12:11 AM
Bub's Avatar
Bub
Thanks.
gnasty1521
35
Nov 19, 2015 11:42 PM
DarkhorSe_SS
Aug 20, 2015 08:58 AM
1bad2k
Aug 18, 2015 09:50 PM
walledition
Jul 29, 2015 08:54 PM
MileHighSierra
Jul 22, 2015 11:19 PM
