Changing Manifolds
Old Mar 21, 2007 | 05:16 PM
MHSLOT12's Avatar
Default Changing Manifolds
Hi Guys Will A Corvette Style Manifoldand Throttle Body Fit On A Truck Engine Easiley Or Is There A Lot Of Mods To Make It Fit .was Thinking Of Putting On A Ls2 Manifold With A 90mm Throttle Body I Have A 2004 5.3l Anyone Have Some Suggestion On What To Do Or What Parts I Should Get To Do The Job Right .. Thanks
Old Mar 21, 2007 | 05:18 PM
thunder550's Avatar
High on diesel fumes
Do a search for LS6 manifold....would be the same work involved in the LS2 manifold.
Old Mar 21, 2007 | 07:54 PM
04BlackSilverado's Avatar
LS6 and the LS2/L92 are a little different.
The LS6 passenger side valve cover gets filtered air from behind the TB, but the air is actually coming from in front of the TB(non vacuum) The LS2 and L92 have a port on the passenger side of the manifold under vacuum. If you just look at the two side by side it looks like its supposed to go there on the LS2 and L92 intakes, its not.
If you do connect the hose from that valve cover to the manifold, you WILL get a very annoying squeal after a while that will sound like a slipping drive belt. The solution is to plumb a 1/4 NPT fitting into your intake tube and you'll be all set. That line just needs filtered air and NOT under vacuum.
Old Mar 21, 2007 | 08:54 PM
bluecajun5.3's Avatar
11 Second Truck Club
thunder550
Oct 8, 2015 04:53 PM
lxcoupe
Aug 24, 2015 08:16 PM
maxspeed05V
Aug 17, 2015 08:41 PM
Ls3silverado
Jul 31, 2015 04:22 PM
Hmguyton
Jul 7, 2015 03:29 PM
