Changing differential and transmission fluid
Old Jan 26, 2003 | 10:00 PM
CashDudeHomie's Avatar
Default Changing differential and transmission fluid
Hey I am changing the differential fluid for the first time since the 4.10 posi install. The housing says to fill with synthetic to 10 mm or something like that below the fill hole. I am using a non synthetic and a tube of friction additive so I was wondering if I need to fill it all the way up to the hole or not???? Also has anyone else had trouble getting the transmission drain plug out??? The thing won't budge and I am worring the head will break off before the bolt will come loose.
Old Jan 27, 2003 | 09:54 AM
MR.QUIK's Avatar
Default Re: Changing differential and transmission fluid
Hey guy what up if I miss spell something let me know so I can get my wife 2 correct it put anyway u should fill the rear end 2 the top of the plug <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jan 31, 2003 | 11:31 AM
ronbuick's Avatar
What tranny do you have??
Ron
Old Feb 1, 2003 | 12:56 AM
Its a 4L60E, the drain plug won't budge even with a breaker bar, I am afraid to pull any harder because I don't want to twist the head off the bolt. Anyone else removed the drain plug without any problems? 2 guys on FSC said the head twisted off before the bolt would come loose. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Oobray
Jun 13, 2022 03:38 AM
Corvette454l88
Sep 1, 2016 01:24 AM
vmaxpro
Aug 8, 2015 10:49 PM
walledition
Jul 29, 2015 08:54 PM
