Changing from a 5.3 to a 6.0
Old Apr 21, 2003 | 11:06 PM
SleekSilverado's Avatar
Default Changing from a 5.3 to a 6.0
What all does it involve? Can you run your same pcm, transfer case, and tranny. Any changes need to be made to the pcm like sensor wise or is it exactly the same? Where would you go about getting one? New or used? What the price range you should look for? Motor mounts diff or the same? Any help would be appreciated
Old Apr 21, 2003 | 11:07 PM
Default Re: Changing from a 5.3 to a 6.0
One more thing, is it really worth it?
Old Apr 21, 2003 | 11:39 PM
redaddiction's Avatar
some guys have gotten a 6.0 and sold their 5.3 and only lost maybe 100 or 200 bucks so if you can do that then you have one hell of a mod if you do the swapping yourself
marc
Old Apr 22, 2003 | 01:28 AM
sleepersilverado's Avatar
very simple just a direct swap. no diffrent parts needed from the 5.3 to 6.0
Old Apr 22, 2003 | 06:58 AM
2ksleeper's Avatar
I believe there is an issue with the crankshaft length for the 6.0 matching up with the 4l60e transmission. I think the older 6.0 engines have longer cranks that won't match up with the 4l60e transmissions. Maybe parish8 will chime in because he has done the swap a while back.
Old Apr 22, 2003 | 04:12 PM
parish8's Avatar
single digit dreamer
the 6.0 needs to be 2001 or newer, it should have the aluminum heads on it too. other than that it bolts right up.
Old Apr 22, 2003 | 04:18 PM
What price range should I look for? Wheres can I get one? My dealer?
Old Apr 22, 2003 | 05:03 PM
ryan99chev's Avatar
Why a 2001 or newer6.0? Is it just because of the heads or what? If i might ask..
