Changed plugs now it sputters
Old Jun 28, 2010 | 05:47 PM
j_ahlheim's Avatar
Default Changed plugs now it sputters
I changed plugs to autolite double platinum and now on easy accel it sputters and hesitates then runs fine at higher rpms. Is it just the computer learning the new plugs or is something wrong. I was under the impression autolite plugs were good plugs.
Old Jun 28, 2010 | 05:52 PM
Mrgoodwrench3's Avatar
First problem is you installed Autolite plugs in a GM motor. Did you put any Dielectric grease in the boots?
Old Jun 28, 2010 | 05:54 PM
Mangled03gmc's Avatar
Baltimore Whore
I have always had great great luck with autolight plugs. But in the ls motor, I will run NGK's only.. Declo, ngk denso, autolight are all great plugs imo.. Are the same heat range as what was in there/?? and are they gapped correctly ??
Old Jun 28, 2010 | 06:01 PM
j_ahlheim's Avatar
I just changed the wires about 1000 miles ago so there was plenty of grease in the plug wires.
Old Jun 28, 2010 | 06:05 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
you broke a wire.
OK it's a guess but pretty commonplace me thinks.
Old Jun 28, 2010 | 06:36 PM
highroller02's Avatar
broken sparkplug is my guess.take them out to see if any are cracked
Old Jun 28, 2010 | 06:50 PM
j_ahlheim's Avatar
DING DING DING we have a winner Mangled03GMC!!!! Ok I'm a idiot I pulled a plug and the gap was .050 and should have been .040 accoreding to my Haynes manuel. I pulled all the plugs and gapped them but a few to many beers to test drive. Hopefully that was the problem. YES I KNOW WHAT A RETARD
Old Jun 28, 2010 | 07:03 PM
SILVERADO11's Avatar
let us know if that fixes your problem, if not may have a bad wire, i had the same problem after i changed plugs e few years ago, the wire looked fine but had high resistance, most likley caused from me pulling so hard on the wires to get them off the plugs. good luck to ya!
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
Hey j_ahlheim where in NC to you live? New Bern here.
Old Jun 28, 2010 | 07:06 PM
j_ahlheim's Avatar
Fort Bragg/Fayetteville here finally someone from around this area.
