Changed heads and cam new times
Well I changed to newer port patriot stage 2 heads, and installed a 220/224 581/581 112 cam in the ss and went to steele al. today for the first runs. I did a lets see what falls apart run with all motor and ran a 14.3, so I am only seeing 8 degrees knock at idle and less going down track. I think this is exhaust hitting cross member. So I run with 75 shot and did 13.01 at 106.71 with a 2.00 60ft, 8.34 1/8 at 84.66. So now I want 12s bad and start to change to 100 shot and break the fitting that the line screws on.(damit) I run all motor after cool down and run a 13.99 at 97.29 with 2.04 60ft. I really want to see what it runs when it gets cooler it was 81 degrees today.
Yep.. the big truck was moving pretty good down there today. I hate that you didn't get to spray it with 100hp, I know how bad you was wanting that 12.9. Cooler weather and some tuning will get you there for sure. I gotta go to bed now, I've been sick all day for some odd reason
