change oil light questions
Old Aug 29, 2003 | 05:25 AM
black_yukon's Avatar
Default change oil light questions
Today I go to start the truck and the check oil light comes on. It stays lit for 10 seconds then turned off. It did it everytime I started the car today. I had the oil changed less than 1000 miles ago. I checked the oil on the dip stick and it looked fine. The last time the light did come on, I thought it stayed on until you reset it??? Any explinations??? Should I get another oil change???
Old Aug 29, 2003 | 05:35 AM
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Re: change oil light questions
Did you try resetting it again?
Old Aug 29, 2003 | 07:34 AM
Mine has done that everytime that I start the truck, stays on for about 5 to 7 seconds. According to my manual it is supposed too. Is your's different? I got a 2003, and it does not have the little info panel on the left of the guages like the earlier trucks. So I mean does yours actually say check oil, or is it a dummy light?
Old Aug 29, 2003 | 08:02 AM
Deckhand's Avatar
turn your key till its just to "part ignition" where the battery shows... then stomp the throttle 3 times in a row, then turn it on..
i think thats what it is.
The oil light is just a reminder to change it according to mileage I believe. So you gotta reset it once you change it.
Deckhand's Avatar
oh, and that will reset the light.
Old Aug 29, 2003 | 10:20 AM
GREGGO's Avatar
The light does not stay on untill you reset it. The instructions for reseting the light are in the owners manual.
1. Turn ingnition to "run" w/o starting the truck.
2. Press the acc 5 times to the floor in 3 seconds.
3. The code will flash 3 times and go off.
4. Turn the truck off.
5. Start the truck and have a nice day.
Old Aug 29, 2003 | 10:22 AM
GREGGO's Avatar
It works off a formula based on engine hours and various sensor readings.
Old Aug 29, 2003 | 12:25 PM
Deckhand's Avatar
cool, now i know..
thanks
Old Aug 29, 2003 | 02:14 PM
sleepersilverado's Avatar
but that does not always work as we have seen in some cases. so i have never paied attention to it any ways so i act like it is not there.
Noah Burns
Sep 7, 2015 05:50 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
Ls3silverado
Jul 31, 2015 04:22 PM
rojeho
Jul 12, 2015 06:10 PM
