"CAT" Removal effect performance?
Old Jul 21, 2005 | 09:46 PM
97'RS6-BucketTurd's Avatar
Default "CAT" Removal effect performance?
Alright, I wasn't sure where to put this so i hope this section of the forum is alright....my friend has a 1998 Dodge Ram 1500 (extended cab) and i'm not sure what exactly happened but his 'CAT' ended up heatign up so bad it f-ed it up and they gutted it....and i looked under his truck and noticed he's got sensors before and after the 'CAT'.
I know on my 'turd Camaro i have the OBDII (or whatever they're called) sensors before and after the "CAT" and if i remember correctly gutting the "CAT" would effect your AFR, or send bogus signals to the PCM and make the car run bad...
So FINALLY lol my question is....Would his truck do the same thing that mine would do?
If so, what do you reccomend doing?
We've thought of a high performance cat but it's got a really weird exhaust set up so it would require a y-pipe/y-collector first. =/
Or do they make sensor trickers like they have for my vehicle?
Orrrr....Does it not matter at all and it's fine as is?
Thank you for your time!
Anthony
Old Jul 22, 2005 | 01:07 PM
38 people and no guesses? lol oh well thanks anyhow, his truck seems to be running fine but it's throwing a check engine code.
Old Jul 22, 2005 | 01:58 PM
white1's Avatar
The rear O2 should just throw a code. Its the front one that adjust timing, fuel etc. He should be good. Not sure how to get the light to go off on a Dodge though.
Old Jul 22, 2005 | 05:25 PM
ahhh alright, i'll tell him to invest in an inch long piece of electrical tape to get rid of that light...lol
Appreciate the help
Anthony
Old Jul 22, 2005 | 06:09 PM
desTRUCKtive's Avatar
yeah the rear O2 will just throw a code. The front ones is what deterimines the proper A/F ratio. But I have no idea on how to delete the light on those.
Old Jul 22, 2005 | 07:00 PM
white1's Avatar
Electrical tape works.
Choda
Jan 22, 2026 02:03 PM
GXPJAY
Feb 13, 2022 08:15 AM
signguy62
Sep 20, 2015 02:05 PM
cbhedrick
Jul 20, 2015 10:12 PM
1320Chicken
Jul 14, 2015 10:58 PM
