Castec Heads on 04 5.3
Old 12-09-2012, 03:00 PM
  #21
redrdrfmx's Avatar
Random question,
Pulled the coolant drain plug on the bottom of the block. Still coolant in the block, what am I forgetting?
Old 12-09-2012, 06:07 PM
  #22
AGearHead4Life's Avatar
Originally Posted by redrdrfmx
Random question,
Coolant wise? You did fine. Thats more than I did. I did it the hard way of course and didnt drain prior. Coolant everywhere. lol It even went down my exhaust pipe. I had to burn the moisture out once I got it started. Everything turned out fine.
Old 12-10-2012, 12:12 AM
  #23
redrdrfmx's Avatar
So I got the new lifters and guides in, heads on, and hoping to get the rest finished up tomorrow. I wanted to clean the valve covers as I believe the pcv is built in (correct?) can I just blast the pcv passageway with some brake cleaner, blow it out with an air compressor and call it good?
Old 12-10-2012, 12:22 AM
  #24
I have a gauge for that
Atomic's Avatar
Yep, thatll be fine.
Old 12-10-2012, 09:53 AM
  #25
Ferocity02's Avatar
Random question,
There are two coolant drain plugs, one per side. Driver side is a big one, needs a 17mm allen head, and the passenger side is smaller and is hidden above the starter. You need to remove the starter to get to it.
Old 12-10-2012, 10:09 AM
  #26
redrdrfmx's Avatar
Pulled the driver side one only, but the truck is on an angled driveway and the driver side is currently lower. I would imagine most of the coolant dripped over to that side. Just not sure why the coolant wont completely drain.
Old 12-10-2012, 11:20 AM
  #27
That PCV usually pulls out of the valve cover. But yes, I just blew it out with brake cleaner and also the chamber that it slide into.
If you have the time I'd drop them off at a machine shop to be cleaned. They're able to clean in there better than I can. I get them back with nice shiney aluminum. Guess it depends on how nasty there are to. I've had some bad ones.
JordanH
08-08-2015 07:59 PM
elpyro89
07-28-2015 05:51 PM
steves86ta
07-28-2015 10:21 AM
vmaxpro
07-27-2015 10:45 PM
06 4.8
07-15-2015 07:17 PM
Quick Reply: Castec Heads on 04 5.3
