Can't get my truck to idle with new 6.0
Old Jun 26, 2005 | 03:54 PM
02sierraz71_5.3's Avatar
Originally Posted by Badzracing
I'm running 43lbhr injectors. I also have a p1sc procharger on it. I have the 4.8 program running it now, with only minor changes to the tuning. I running speed-density, so the MAF is doing nothing. I don't know what my problem is with the 2 cylinders not running right. I've tried everything including changing plugs, wires, and even the coil packs. No vacuum leaks that I can find. It was running pretty good last night, but today it's running shitty. The fuel trims are not that far off. It's adding fuel in some places and subtracting in others ( not a whole lot , though either way). Could the timing be WAY off do to the dramatic change in cam profile?
How did you tune the injectors?
Have you checked to make shore the injectors are actually firing, sounds like the injectors are bad on those two cylinders or clogged. Where they new when you got them I would dump alot of injector cleaner in with 5 gals and try and see if that helps. friend had a similar problem and he dumped in alot of injector cleaner and it unclogged them in a couple days.
check out the injector tuning section
https://ls1tech.com/forums/showthread.php?t=287094
Old Jun 26, 2005 | 04:02 PM
They worked great on the 4.8, but god knows if they're dirty now. I may just go ahead and try cleaning them. I'm also starting to think that maybe a valve seal or two is screwed even though they are brand new. I just don't know what the hell else could be the problem. I personally am not the "tuner", my cousin is. He knows what he's doing, even though it's still a learning process for him. I think this whole new cam thing kinda has him a little stumped. However, the problem now seems to be of a mechanical nature and not a tuning issue.
Old Jun 26, 2005 | 04:40 PM
If I were you I would start all over. Start with a tune meant for a stock 6.0 and do the ifr table first for the injectors. As far as tuning for a larger cam the best way I found is to go ahead and reduce the stock 6.0 table by 25% then tune in SD using fuel trims and adjust the ve table accordingly it isnt that hard. Just make shore to reset trims after altering the ve table.
Throwing the FI in with a larger cam is gonna be a sob to tune, all the info he needs though is in the pcm section.
As far as trouble shooting mechanical problems I would be logging injectors and misfires also. If its using alot of oil you know youve got some blowby then or other problems.
Old Jun 28, 2005 | 10:38 AM
Ok. It turns out I had a pinched injector wire. It was grounding out and holding the injector open. Now that it's taken care of, the engine is running pretty good ( even on the 4.8's old tune). Thanks for all the help and suggestions you guys gave me. I really do appreciate the the help.
GrooveCityZ71
Aug 31, 2015 12:05 PM
wrb002
Aug 31, 2015 12:00 PM
black6spdz
Jul 16, 2015 01:32 AM
GreyChevy
Jul 7, 2015 08:57 PM
Breitling
Jul 6, 2015 06:39 PM
