Cant get intake to fit TSP 408
Old Mar 27, 2010 | 08:35 PM
dirt track racer 81's Avatar
Default Cant get intake to fit TSP 408
Trying to get an intake on a TSP 408 and dowels on the intake do not want go into the heads. The heads are TSP 317 heads and the intake is an LS1 intake. It fits fine on the LS1 but not the 408. The motor was built for boost and I wouldnt think the heads would have been milled.
Old Mar 27, 2010 | 08:38 PM
GMCtrk's Avatar
That's weird, there should be no difference whatsoever in the intake holes on the 317s, whether they're modded or not.
Old Mar 27, 2010 | 08:44 PM
Uh huh...Thats what I said fits just fine on the ls1 block but not this block
Old Mar 27, 2010 | 08:45 PM
GMCtrk's Avatar
That's what you get for putting a crappy LS1 intake on a 408. lol.
Old Mar 27, 2010 | 09:07 PM
Not my motor.. its going in an LS1 GTO with a procharger..
Old Mar 27, 2010 | 09:21 PM
SincalT/A's Avatar
Valley cover/bolts too tall?
Old Mar 27, 2010 | 09:22 PM
GMCtrk's Avatar
Do you have any other intakes lying around you could try? Any chance the LS1 intake is warped?
Old Mar 27, 2010 | 09:29 PM
The valley cover and bolts came off the ls1 the intake came off of. I did pull the bolts out and it still didnt fit. I did measure the distance in the bolts holes across the head and the 408 was a 1/16th of an inch closer than the ls1..
Old Mar 27, 2010 | 10:03 PM
2004SSS's Avatar
how much did they deck the block ?
how much are the heads milled?
they can both bring down the distance between bolt holes from bank to bank .
i recently had to over come this on my 427 , the intake runners needed to be moved out to line up with the manifold bolts , luckily i had a sheet metal intake and i used some exhaust manifold spreaders to separate the runners enough to get the bolts in , in your case you dont have that option. are the bolts to far apart or not far enough ?
Old Mar 27, 2010 | 10:08 PM
GMCtrk's Avatar
If the measured distance between the intake manifold bolt holes in the heads are different than the LS1 heads than that shouldn't have anything to do with the amount anything was milled I would imagine. I just can't see a GM casting like that passing QC. Are you certain these are GM castings?
