Cant get intake to fit TSP 408
Old Mar 27, 2010 | 10:48 PM
dirt track racer 81's Avatar
Originally Posted by 2004SSS
how much did they deck the block ?
how much are the heads milled?
they can both bring down the distance between bolt holes from bank to bank .
i recently had to over come this on my 427 , the intake runners needed to be moved out to line up with the manifold bolts , luckily i had a sheet metal intake and i used some exhaust manifold spreaders to separate the runners enough to get the bolts in , in your case you dont have that option. are the bolts to far apart or not far enough ?
Only thing I know on the motor is that its a 408 built for boost with cnc milled 317 heads.. Ive put on heads that were milled and had no problem.. How much decking/milling did you have?
Originally Posted by GMCtrk
If the measured distance between the intake manifold bolt holes in the heads are different than the LS1 heads than that shouldn't have anything to do with the amount anything was milled I would imagine. I just can't see a GM casting like that passing QC. Are you certain these are GM castings?
yes they are GM castings. I didnt even try to put the bolts in because the intake did not even try to seat.
Old Mar 27, 2010 | 11:54 PM
cheyenne383's Avatar
TOWN CRIER
I had a decked block and milled heads on an SBC and when I tried to put the pain in the *** Super Ram intake on it the intake runners wouldn't line up and neither would the bolts (wouldn't seat all the way in the valley). Measure across the top of the block between the heads and see if the block has been decked, if so get to work cutting up more stuff... gotta love modding cars with a bunch of different people involved.
Old Mar 28, 2010 | 12:26 AM
budhayes3's Avatar
PT's Slowest Truck
I'm familiar with this happening when blocks and decks have been milled, used to see it on sbc's all the time, you might need something custom for an intake...
5.3Okasai
Mar 9, 2022 01:07 PM
TXsilverado
Nov 26, 2015 10:54 AM
Aboss
Aug 11, 2015 09:05 AM
Denali08
Aug 9, 2015 04:34 PM
Ammadien
Jul 22, 2015 08:50 PM
