can you break a piston if you don't detonate?
Old Feb 18, 2003 | 09:33 PM
parish8's Avatar
single digit dreamer
Default can you break a piston if you don't detonate?
i am going to ask this in a couple of areas and i though i would see what you guys think.
i have a nx kit on the way, i think the motor can take it(6psi+50shot) for awhile but i am wonder what part will fail first if i ever push it harder. i will not let it run out of fuel. i have a fuel presure gauge and a wide band. i will increse power in small steps, log everything, if i run out of fuel pump i will stop and fix that problem. i will not let it detonate, i will log that and keep my knock sensors active, add better gas as required to keep out of detonation.
so what will break if i keep uping the boost/nitrous. will i pop a head gasket, spin a bearing, break a pistion? anyone have a guess?
Old Feb 18, 2003 | 09:40 PM
sleepersilverado's Avatar
Default Re: can you break a piston if you don't detonate?
jmo: i think you will lift a head or spin a bearing.
but then again i dont know if lifting a haed only has to do with high boost aps. i dont know lets find out <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 18, 2003 | 09:45 PM
Texas Terminator's Avatar
11 Second Club
replied in forced induction...
Old Feb 19, 2003 | 11:06 AM
BigTex's Avatar
I agree on the head gasket or spun bearing. Another possibility is a rod bolt letting go. The stock LQ4 has plain cast pistons which aren't as strong as a the LS1's hypereutectic piston. I would think the cast piston would break easier. I guess it all depends on how much cylinder pressure is really being made and how many rpms you are taking it to.
Old Feb 19, 2003 | 11:09 AM
Pro Stock John's Avatar
Registered User
I think:
1) Could have some detonation if you run it too aggressive, lift a head slightly, and we have head bolts that stretch. Most hydraulic'd motors are due to stretched headbolts IMHO.
2) Rod bolt issue I see more of a high rpm issue.
Old Feb 19, 2003 | 06:29 PM
GoldenVelvet's Avatar
From everything ive read the pistons are weak link in the short block. Ive heard of pistons giving up more than anything. (especially the #7)
<img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" />
Old Feb 19, 2003 | 06:48 PM
parish8's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by goldenvelvet:
<strong> From everything ive read the pistons are weak link in the short block. Ive heard of pistons giving up more than anything. (especially the #7)
<img border="0" alt="[bomb]" title="" src="graemlins/gr_bomb.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i agree 100% but i think it is due to detonation, i have a wide band so i will not run lean, will run good gas, will log for detonation and not run if i see any. the piston may still be the first to go, who knows. just wondering what others think. i am sure i will be the tipical nitrous addict and not be able to control myself, aww, just swap out the pills to the next size <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> . but i have all the tools at hand to be a carefull nitrous addict.
Gadgetized
Aug 21, 2020 03:14 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
JordanH
Aug 8, 2015 07:59 PM
rudvirus
Jul 15, 2015 09:31 AM
