Can Someone Plz Tell Me Whats Going On Here??
Old Jan 7, 2006 | 02:28 PM
TravisH's Avatar
Default Can Someone Plz Tell Me Whats Going On Here??
My truck still wont start. the fuel rails are full of fuel but I guess the injector arent dumping in any fuel into the motor. Are they clogged up? should I remove them ane soak them in injector cleaner?
I need a beer
Old Jan 7, 2006 | 03:56 PM
Allgonoshow's Avatar
do you have spark
Old Jan 7, 2006 | 05:01 PM
TravisH's Avatar
the injectors I bought from a member on here were bad......as in none of them would deliver fuel. put the stockers back in and it fired right up.
Old Jan 7, 2006 | 06:00 PM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Options:
#1 - Try to contact the member, be civil, and request a refund.
#2 - Post a comment in the Member Feedback section.
#3 - Go lookin' for that member, and shove each injector where the sun don't shine.
You be the judge!
** This post is not to give any direction to inflict harm on any other member in this forum. Options #1 & #2 are preferred. This is for entertainment purposes ONLY! **
Old Jan 7, 2006 | 11:56 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Could the injectors have been low impedance? Your truck wouldn't have had drivers to fire them. What size/brand were they? Either way they don't work for you but, they may work for someone else. Get the info on them and report back.
Old Jan 9, 2006 | 08:39 PM
TravisH's Avatar
They were stockers off an 02 silverado. I contacted the member and he gave me a few tips to clean them because he said they had been sitting for a little while, then when I got them they sat in my garage for a few months. I am going to try using some B-12 cleaner to clean them than I will reinstall them and see what happens. I will only take me about 10 minutes to reinstal them since I am so good at that now...
Old Jan 9, 2006 | 09:14 PM
Dark Halo's Avatar
sorry to hear about your mishap. I have a set of used injectors I have bought off a member that I have not installed yet. I may consider cleaning them before I install them now.
Old Jan 9, 2006 | 09:46 PM
TravisH's Avatar
ya deffinatly clean them up. you dont know how long they have been sitting in his dusty garage. I think you can get the stuff at NAPA, I think it is called like Baramans B-12. then ya squirt some of that in it and blow it out the other way with a rubber nozzled air hose. That stuff is pretty badass Ive heard I will pick some up tomarrow hopefully and see if it works!
00Silv4.8
Jan 30, 2008 12:02 PM
xdanny510x
Nov 7, 2007 08:23 PM
*WILDSTYLE 5.3*
48
Jun 4, 2006 12:33 AM
*WILDSTYLE 5.3*
Feb 13, 2006 09:32 AM
