can i reuse my gaskets
Old Mar 11, 2007 | 04:14 AM
javier4.8's Avatar
Default can i reuse my gaskets
can i use my stock factory head gaskets. im going to switch out my heads and dont have anyother car parts dealer open on a sunday that have the gaskets..
Old Mar 11, 2007 | 04:25 AM
Derek @ EDO's Avatar
FormerVendor
No, you need new ones. Your not suppose to re-use the stock head bolts as well.
Old Mar 11, 2007 | 04:56 AM
LesPaul's Avatar
how many miles and mods....... Just to let you know.. i reused my gaskets on my 5.3l at 100,000 miles and no leakes or nothing... i also reused my bolts....
Old Mar 11, 2007 | 05:42 AM
TXsilverado's Avatar
buy new gaskets and bolts.
Old Mar 11, 2007 | 10:59 AM
Quik's Avatar
5 year bitches!
thats the only gasket not reusable
and no way in hell to use stock bolts again
Old Mar 11, 2007 | 11:14 AM
VicRed's Avatar
I dont see how you would be able to reuse the head gaskets more than once. When I pulled my heads there was gasket material stuck to both the heads and block. I replaced mine with MLS gaskets.
Old Mar 11, 2007 | 11:16 AM
xlcooplx's Avatar
definitely dont reuse the stock bolts. they're a torque-once bolt. they're done with after used once. PartNumber (12498545) is for 99-04 LS1's. Not sure if they're the same for the 4.8/5.3
Old Mar 11, 2007 | 11:39 AM
Flyer's Avatar
New head gaskets. The other gaskets should be fine though, but definantly new head gaskets.
You could get away with using the bolts again before you could the gaskets. I've seen people reuse the bolts before, but like said, it's not best practice to do it that way.
Old Mar 11, 2007 | 11:56 AM
javier4.8's Avatar
do any of yall know the part # or can yall tell me what kind of bolts and gaskets to use
Old Mar 11, 2007 | 12:05 PM
Quik's Avatar
5 year bitches!
for like 80 bucks there isnt a reason to be cheap
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
bearden86
26
Nov 15, 2015 03:58 PM
1989k1500
Sep 29, 2015 10:53 AM
sTNT971
Sep 26, 2015 04:22 PM
