can i drop the crossmember?
Old May 1, 2009 | 05:51 PM
fredkj3's Avatar
Default can i drop the crossmember?
can i pull the crossmember and drop the oil pan??? i need to get to my O ring for the oil pump... because i have no oil pressure.. and id rather not pull the water pump, balancer, and timing cover.....
so can i pull the crossmember and drop the oil pan??? or would it be easier to pull the front of the motor back apart???
thx guys
Old May 1, 2009 | 05:53 PM
GMCtrk's Avatar
To get at the o ring you have to lower the oil pan slightly, I'd say you could do it either way depending on which one you're more comfortable with.
Old May 1, 2009 | 06:39 PM
fredkj3's Avatar
i know you can drop it a little if you have the timing cover off.... but what about with the timing cover on.....
flatblack83
Jan 3, 2026 07:10 PM
01silvy
Sep 26, 2015 10:20 PM
97_ek
Sep 23, 2015 09:16 PM
69z-28
Sep 21, 2015 07:31 AM
spooneralmighty
Sep 11, 2015 02:28 PM
