Can a crew cab 5.3 be fast? Apparently not
Old 06-18-2005, 09:33 PM
  #21
quicksilverado's Avatar
Originally Posted by stssilverado
It takes my foot to the floor to even break loose in the staging lanes. Absolutely no loss of traction. 60' 2.47 330' 6.65 1/8th 10.2 1/4 15.7 @86.26 mph.
It is now obvious I need a retune. My opinion is, Allen, doing the right thing, was way too conservative on my mail order tune. I don't blame him. Without the dyno results you could hurt the motor.
8psi sts, non intercooled, 2800 tci stall, injectors, fuel pump.
Do you have a meth kit on the truck. If not without meth or an I/C your IAT is probably hurting you at 8 psi in the summer heat.
Old 06-18-2005, 09:43 PM
  #22
I AM A MOTHERF*CKER
TurboBerserker's Avatar
I'm not sure how far you are from Allen, but being able to sit in the truck goes a helluva way towards a better tune -- even if he doesn't get her on the dyno.
Turbos can be tricky to tune -- lots of factors in the equation. Make sure you can check your KR, your fuel pressure, your boost (assuming you have a boost gauge and are not going on what the spring should be giving you).
I ran 7.5psi without meth on higher compression, but I tuned for it.
Are you able to log? That will also help Allen out if you can't get to him.
Old 06-18-2005, 10:16 PM
  #23
stssilverado's Avatar
will try to get tune next week
Old 06-18-2005, 10:32 PM
  #24
Destroyer of Transmissions
1SlowHoe's Avatar
Could this have anything to do with the traction control (if so equipped) not allowing the truck to go into power enrichment? If you have TC, turn it off before you run. Seems to make a difference on my Tahoe, on the street anyway, I haven't made it to the track yet
Old 06-18-2005, 10:50 PM
  #25
02sierraz71_5.3's Avatar
time to invest in hp tuners sounds like your serious enough to learn how to tune
its the best modding investment ive made to date it taught me alot
Old 06-18-2005, 11:49 PM
  #26
Adkoonerstrator
XLR8NSS's Avatar
2.47 60'
With a turbo @ 4-5psi on the line and a 2800 stall that should be MUCH better.
Something definately ain't right.
Old 06-19-2005, 12:58 AM
  #27
zippy's Avatar
i would have to agree that something isn't right for sure. on the other hand it is an STS kit. they put down great numbers on the dyno...
Old 06-19-2005, 09:27 AM
  #28
bud8fan's Avatar
they put down great numbers on the track also.....get with allen and see what he thinks bout your problem...i think you need a meth kit to get you temps down so it doesnt pull so much timing from the motor...dont know unless your logging the info thou...
Old 06-19-2005, 09:33 AM
  #29
Banned
litreddevil's Avatar
Originally Posted by BlownChevy
CAPS LOCK SUCKS!
What are his mods?
I ALL WAYS TYPE IN CAPS F*CK HAVEING YO KEEP HITTING THE BOTTONS.
HE HAS 4.10,TB CONVERTER,PACESETTERS,E-FANS,PULLEY,CAI,PORTER TB,AND A CUSTOM TUNE BY THUNDER.NOW HE ALSO HAS A SET OF HEADS SHAVED 30TH AND 3 ANGLE VALVE JOB
Old 06-19-2005, 10:42 AM
  #30
zippy's Avatar
really. i see you had one. what did yours run?
Quick Reply: Can a crew cab 5.3 be fast? Apparently not
