Cams and Emission testing
Old Dec 9, 2004 | 09:43 PM
chevymec's Avatar
Default Cams and Emission testing
Anybody ran into problems passing the sniffer test. Our county should be gettin emissions testing here soonand Id hate to install a cam and it fail the test.
Old Dec 9, 2004 | 10:11 PM
Yelo's Avatar
As long as you keep duration under 220 and LSA over 112 you should pass a sniffer test fine.....asuming the tester doesn't hear/care about the slightly rough idle
Old Dec 9, 2004 | 11:04 PM
GREGGO's Avatar
Are they even going to sniff? Most 96 and newer only get the PCM hooked up checking for codes and "not readies". Mine passed (no sniff) with a 4.8 running a 212/218 522/529 114 and NO custom tunning.
Old Dec 9, 2004 | 11:17 PM
chevymec's Avatar
iIve heard that there will be a sniffer and that ther wont be.
GREGGO, im lookin at the same cam that you have. I just passed one up cheap cause i was slow to the draw Does it have a noticable lope through the exhaust?
Old Dec 10, 2004 | 05:56 AM
one03sierra's Avatar
Formerly one92rs
Talking
i have a 216-220-525-532-114 and it passed. they did not hook a sniffer to it. all they do is hook to the pcm.
sfj
not a bad one but yes it does have a lope it sounds pretty damn good if you ask me
Old Dec 12, 2004 | 12:03 AM
(Ken)-96GMC K1500 SC's Avatar
I just smoged my 383 with this cam with 50 miles on the truck on the smog dyno it passed a tad higher than a stock 5.7 would put out with a stock cam but still with plenty of room. James B. also had the same cam for a while installed in his 350 SC Tahoe and it passed about the same readings.
http://www.crower.com/misc/cam_spec/...401LM&x=39&y=7
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 269º Lift: 0.474 Clearence Hot: 0
EXHAUST: Duration: 278º Lift: 0.498 Clearence Hot: 0
LOBE SEPERATION 114º
Duration at .050" Intake: 214, Exhaust: 220
Smog readings:
15 mph, RPMS 1786
15 mph %CO2 15.2
15 mph, %O2 0.1
15 mph, HC (PPM) Max 103, Avg 10, Measured 36
15 mph, CO (%) Max 0.58, Avg 0.02, Measured 0.16
15 mph, Nox (PPM) Max 986, Avg 103, Measured 117
25 mph, RPMS 1775
25 mph, %CO2 15.2
25 mph, %O2 0.0
25 mph, HC (PPM) Max 92, Avg 8, Measured 23
25 mph, CO (%) Max 1.02, Avg 0.02, Measured 0.21
25 mph, Nox (PPM) Max 846, Avg 97, Measured 105
Ken
thunder550
Oct 8, 2015 04:53 PM
superchomper2003
Aug 26, 2015 09:39 AM
noproblems209
Aug 10, 2015 06:57 PM
Jake99
Aug 8, 2015 07:56 AM
Suburban2500
Jul 13, 2015 09:57 AM
