cams
Old Sep 4, 2007 | 10:34 PM
  #41
99Silverado5.3's Avatar
Im guessing you have a degree wheel to install it on a 106...
110-4=106
Old Sep 4, 2007 | 10:35 PM
  #42
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by Rhino79
Well, 110 lsa and it has 4* advance in it, I think it should be 106 just installing it straight up. Wouldn't be a bad idea to check it though.
Just figured with the cam specs getting all technical it would be a good idea to check it.
99silverado-He has a vic jr and full length dual exhaust I think he will be just fine
Old Sep 4, 2007 | 10:38 PM
  #43
Rhino79's Avatar
9 Second Club
And a 4bbl......with a K&N.
Old Sep 4, 2007 | 10:44 PM
  #44
Why would he need to degree it to 106 if it is 110 with 4* advanced Installing it straight up? 110-4=106 correct? You would not have to degree it to 106 since the 4* of advance.
Or am I confused???
Old Sep 4, 2007 | 10:46 PM
  #45
Rhino79's Avatar
9 Second Club
Your right, I was just reading from Patrick G's spec sheet. It should be straight up, but its always good to double check that it is actually what it is supposed to be.
Old Sep 4, 2007 | 11:14 PM
  #46
RandomHero's Avatar
so can anyone explain this then?
Old Sep 5, 2007 | 05:48 AM
  #47
tdrumm's Avatar
What do you want to know?
Old Sep 5, 2007 | 05:59 AM
  #48
Oh ok, thought you were 100% on what the cam was.
Yes, it would be a good idea to know what the cam is speced at before you put it in lol.
Should be a beast though.
What? How it relates to 243, 317, ect.. heads?
Old Sep 5, 2007 | 08:40 AM
  #49
RandomHero's Avatar
that's a graph for a stock 5.3L head. Anybody care to explain scienficially how running a cam with .575 lift would gain more than a couple rwhp than running one with .520 lift?
Old Sep 5, 2007 | 08:53 AM
  #50
Phantom's Avatar
11 Second Club
i made more power to a higher rpm with my low lift comp 212/218 than i did my 216/224 .551 115lsa vinci cam. my 212/218 is still making power at 6300 where i shift, where the 216/224 started to fall on its face at 5750. mark i don't know if that helps you out any but i thought it was pretty interesting
