Camaro needs help from truck guys
Old Jun 27, 2005 | 07:01 AM
1blackz28's Avatar
Default Camaro needs help from truck guys
I asked this question in ls1tech and no one has been able to come up with a difinite anwser. Can someone take a truck maf and put it in a camaro if so what kind of calibrations would be needed.
Old Jun 27, 2005 | 07:10 AM
onyx's Avatar
14 Second Truck Club
dont see why not. wouldnt a z06 maf be better though? alot of people switch to those for some reason.
Old Jun 27, 2005 | 07:33 AM
1blackz28's Avatar
I heard that the truck maf have an intergrated IAT sensor and are a little different than the fbody. GM has two different part numbers one for 6.0 and zo6 and one for fbody.
Old Jun 27, 2005 | 11:26 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Truck MAfs are the 5 wire (IAT included variety). If you spliced the right plug into your wire harness (and ignored the IAT pins), it should work fine. You could grab the MAF tables from the year vehicle you snatched the MAF from.
Old Jun 27, 2005 | 12:17 PM
1blackz28's Avatar
Ok cause the guy at autozone said "we dont have one for a camaro but the truck one will fit" so I bought it anyway cause mine was severly screwed and now my LTFT are lean. Could that be the problem cause I didnt even know about the internal IAT in them. Just pluged it in and went. Seems to drive and run ok.
Old Jun 27, 2005 | 03:24 PM
zippy's Avatar
SLP has been selling them for quite a while for camaro's. should work fine...
Old Jun 28, 2005 | 12:01 AM
Z284thgen's Avatar
11 Second Club
the truck maf and Z06 are damn near the same both 85mm only the z06 has no screen from the factory
yes the wiring harness is different and it for sure will need tunning on the tables swapped mine out on the dyno( talking about the Z ) and it went into the 10:1 a/f
had swaped it at the track and ed put a tune in it for the maf and gained almost 2th's just from a swap and the correct tables ( well it was close )
Go5.3tt06
Sep 12, 2015 09:29 AM
Blwn99x
Aug 2, 2015 09:51 PM
black6spdz
Jul 16, 2015 01:32 AM
gcsd3742
Jul 6, 2015 05:22 PM
ALynch
Jul 6, 2015 09:49 AM
