Camaro needs help from truck guys
I asked this question in ls1tech and no one has been able to come up with a difinite anwser. Can someone take a truck maf and put it in a camaro if so what kind of calibrations would be needed.
I heard that the truck maf have an intergrated IAT sensor and are a little different than the fbody. GM has two different part numbers one for 6.0 and zo6 and one for fbody.
Ok cause the guy at autozone said "we dont have one for a camaro but the truck one will fit" so I bought it anyway cause mine was severly screwed and now my LTFT are lean. Could that be the problem cause I didnt even know about the internal IAT in them. Just pluged it in and went. Seems to drive and run ok.
the truck maf and Z06 are damn near the same both 85mm only the z06 has no screen from the factory
yes the wiring harness is different and it for sure will need tunning on the tables swapped mine out on the dyno( talking about the Z ) and it went into the 10:1 a/f
had swaped it at the track and ed put a tune in it for the maf and gained almost 2th's just from a swap and the correct tables ( well it was close )
Blwn99x
Aug 2, 2015 09:51 PM
gcsd3742
Jul 6, 2015 05:22 PM
