Cam Without LTs - Worth it?
Old Sep 13, 2011 | 07:38 PM
madmaro00's Avatar
Default Cam Without LTs - Worth it?
I've got an '02 5.3L swapped in my '67 Bronco. The motor is a very tight fit and I do not have room for LTs. I am simply running the tubular manifolds off an '02 Camaro SS. I'm itching for more power and am looking for a good torque cam. Being I can't do LTs will I still see good gains with a cam or will it not be worth the money?
Old Sep 13, 2011 | 07:51 PM
charcoal03silvy's Avatar
You'll see gains no matter what
Old Sep 13, 2011 | 07:56 PM
TIM Z's Avatar
11 sec. Truck Mod
Oh yeah, you can see 30+ horse with the right cam.
I ran a 212-218 in my 04 silverado with stock manifolds.
But a stall converter will really compliment your new cam.
Do it!!
Old Sep 13, 2011 | 08:43 PM
jrmchevyman's Avatar
Too bad you can't do Long Tubes or you could go higher sized cam vs most people since you have a manual transmission.
Something like a 212/218 like already stated would be fine or have someone like EPS spec you out a custom grind cam for your application. The stock SS camaro manifolds aren't that bad for being manifolds, but long tube headers are a lot better.
If you could somehow do Headers this would be a good cam below:
If you spoke to a tech at Thunder Racing they would probably recommend you the TR TRuTorq Level 1 - 219/224 .609/.604 115 LSA If you could do HEADERS, as I know someone else was recommended that one with a 5.3L manual.
I don't think the rest of the guys caught you had a NV4500 swap.
Old Sep 13, 2011 | 10:22 PM
madmaro00's Avatar
Thanks for all the replies guys. My pass side head is about 8" above the frame frail. I had to modify the stock manifold quite a bit to get it to fit. It would take a custom shop a looooong time to make headers, I had a couple quotes around 2k which is obviously not worth it.
I will definitely be doing a cam, thanks guys!
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
Chiphead
Aug 1, 2015 04:43 PM
steves86ta
Jul 28, 2015 10:21 AM
ssierra08
Jul 15, 2015 06:40 AM
