Cam Swap (Truck vs FBody)
Old Aug 16, 2009 | 06:04 PM
Hawaiian_Built's Avatar
12 Second Club
Default Cam Swap (Truck vs FBody)
Whats the differences?
I've done a cam swap on my camaro by myself using www.ls1howto.com about a year ago. I'm looking to do a swap into my 5.3l and want to know if any the differences in the truck vs the fbodies. I know when asked about cam swaps, everyone just directs people to ls1howto, and thats fine if its all the same.
Old Aug 16, 2009 | 06:08 PM
00Silv4.8's Avatar
you can pretty much do the exact procedure. You dont HAVE to take the radiator out but its easier. Basically drain all the fluids, pull timing cover pull cam gear, pull the cam out with 2 water pump bolts. Then repeat in reverse basically. Make sure timing marks are lined up and then your done.
Old Aug 16, 2009 | 07:08 PM
viciousknid's Avatar
Where's the Beef?
The blocks are the same aside from iron and aluminum. just make some room in the front and do the swap
Old Aug 16, 2009 | 07:14 PM
Mangled03gmc's Avatar
Baltimore Whore
All the same, other then having alot more room with the truck
Old Aug 16, 2009 | 07:15 PM
GMCtrk's Avatar
so the radiator does NOT have to come out to swap cams?
Old Aug 16, 2009 | 07:19 PM
Where's the Beef?
the cam will fit carefully with the radiator there but it's easier with it out considering the radiator is very easy to remove and your draining the antifreeze anyway.
You don't have to worry about scrapping it up when removing/installing the crank pulley
lukesdad04's Avatar
I had to pull the radiator on my 08 truck to do the swap.
Old Aug 16, 2009 | 07:20 PM
12 Second Club
That would help alot. Can someone confirm this?
Old Aug 16, 2009 | 07:21 PM
Where's the Beef?
It only takes another 60 seconds to take the radiator out.
Old Aug 16, 2009 | 07:28 PM
LMSeven's Avatar
The radiator does not have to be pulled. But it's easy.
