Cam swap tips
Old 02-14-2012, 05:12 AM
11 Second Truck Club
Sn0wBa11's Avatar
Unfortunately, yes lol
Old 02-14-2012, 07:38 AM
AndysC3's Avatar
screw the water pump bolts into the cam. It will make it easier to pull out and keep level.
Old 02-14-2012, 09:34 PM
Whitecrewcab's Avatar
thats a good tip about the bolts, never thought about that lol
Old 02-14-2012, 09:43 PM
dmelvin's Avatar
This is what I did when I did mine, makes it so much easier. Be sure that you don't shove the cam back very much when you go to thread them in.
Old 02-22-2014, 08:10 AM
13 Second Truck Club
LS1FREEK's Avatar
Man i'm almost certain I didn't even have to remove the radiator to get the cam out on my 06... Anybody know If I need to on an 09?
Old 02-22-2014, 08:42 AM
grey matter 04's Avatar
Get 2 wooden 5/16 dowel rods to hold the lifters up.
Old 02-22-2014, 11:07 AM
Flyin 1500's Avatar
I used dirt track racers balancer install tool and it was easy. I think there is a link in the member parts section. ls1how to has a good write up on cam install as well. Don't forget to swap your springs and pushrods. I also bought a tool to lock the flywheel in place for the crank bolt install, but found that wrapping an old serpentive belt around the balancer and an idler pulley kept the motor from rotating. Also make sure you get a big enough breaker bar to install the bolt. Its easy! Good luck.
OHsixLS3
12-27-2016 09:30 AM
Stainless Works
11-20-2015 08:55 AM
GrooveCityZ71
08-31-2015 12:05 PM
WICK3DxGATA
07-21-2015 06:59 PM
Aboss
07-09-2015 10:28 AM
Quick Reply: Cam swap tips
