Cam swap tips
Old Feb 14, 2012 | 05:12 AM
Sn0wBa11's Avatar
11 Second Truck Club
Unfortunately, yes lol
Old Feb 14, 2012 | 07:38 AM
AndysC3's Avatar
screw the water pump bolts into the cam. It will make it easier to pull out and keep level.
Old Feb 14, 2012 | 09:34 PM
Whitecrewcab's Avatar
thats a good tip about the bolts, never thought about that lol
Old Feb 14, 2012 | 09:43 PM
dmelvin's Avatar
This is what I did when I did mine, makes it so much easier. Be sure that you don't shove the cam back very much when you go to thread them in.
Old Feb 22, 2014 | 08:10 AM
LS1FREEK's Avatar
13 Second Truck Club
Man i'm almost certain I didn't even have to remove the radiator to get the cam out on my 06... Anybody know If I need to on an 09?
Old Feb 22, 2014 | 08:42 AM
grey matter 04's Avatar
Get 2 wooden 5/16 dowel rods to hold the lifters up.
Old Feb 22, 2014 | 11:07 AM
Flyin 1500's Avatar
I used dirt track racers balancer install tool and it was easy. I think there is a link in the member parts section. ls1how to has a good write up on cam install as well. Don't forget to swap your springs and pushrods. I also bought a tool to lock the flywheel in place for the crank bolt install, but found that wrapping an old serpentive belt around the balancer and an idler pulley kept the motor from rotating. Also make sure you get a big enough breaker bar to install the bolt. Its easy! Good luck.
OHsixLS3
Dec 27, 2016 09:30 AM
Stainless Works
Nov 20, 2015 08:55 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
WICK3DxGATA
Jul 21, 2015 06:59 PM
Aboss
Jul 9, 2015 10:28 AM
