cam swap thread - detailed q's
Old Nov 23, 2005 | 08:54 PM
negativeswitches's Avatar
yeah i was thinking of heating it in the oven and using hot gloves
thanks everyone for your responces!!!
-erik
Old Nov 24, 2005 | 07:39 AM
samdogmx's Avatar
8 Second Club
i just tapped it tiwce with a deadblow hammer & it went on far enough i could get teh bolt started & pulled it the rest of the awy with the bolt. I would say just reuse your stock valve seals & locks, get them Ti retainers, the new chain & rod bolts are good insureance.
Old Nov 24, 2005 | 08:42 AM
BigBlockChev572's Avatar
I used a longer Bolt to put the pulley on. It worked fantastic. I wouldn't recommend heating the crank pulley, JMO.
Old Nov 24, 2005 | 03:43 PM
100k miles i;m gonna get new seals whil i'm in there, i'm thinkin about the steel retainers for the cost of the ti's, i may replace the locks if they are cheap enough
-Erik
Old Nov 24, 2005 | 05:11 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by fogle04
man i would at least use something to hold the lifters up.
I flipped the engine upside down on the engine stand, turned the cam a dozen times and pulled it out, slid the new one in.
Old Nov 24, 2005 | 05:17 PM
TarheelZ's Avatar
Good ol' Southern ingenuity!
Old Nov 24, 2005 | 10:07 PM
anyone know if tsp's or sdpc's gasket kit comes with the longer bolt
i heard tsp's does but i jsut assume buy everything from a perf. trucks sponsor.
Old Nov 25, 2005 | 03:04 AM
Mr. Sandog's Avatar
Yeah, there's just that minor inconvenience of blowing up a motor to get one on the stand you can do that to. Small price to pay, right?
Old Nov 25, 2005 | 06:55 AM
JimS's Avatar
Anyone make a rotisserie (sp?) for the whole sheeebang?
Old Nov 25, 2005 | 09:30 AM
hellbents10's Avatar
LS1Tech Sponsor
If you ahve a nitrous bottle laying around....I spray the crank with a little n20 and heat the pulley a bit not enough to hurt the seal, then it will slide right on there.
