Cam swap in progress
Old Dec 30, 2005 | 08:42 PM
mattrem's Avatar
Default Cam swap in progress
Well I decided tonite to get the cams swapped out and get it done. This is my second cam swap and it just gets easier. I just got the new cam and and it took about a hour and a half by myself to get the old one out and the new one in. I didn't even use the tools ( which are a waste of money anyway) or any magnets. Well I am going back to work, check back later
Old Dec 30, 2005 | 08:58 PM
tdrumm's Avatar
Gonna take it out for a test drive tonight?
Old Dec 30, 2005 | 09:18 PM
BigTex's Avatar
I'm really eager to hear how this cam runs compared to your previous setup. It should be an all around better setup.
Old Dec 30, 2005 | 11:20 PM
mattrem's Avatar
Well I am done for the night, I am just beat. All I gotta do tommorrow is put the water pump on, put the radiator back in,and the coils. Not a bad night considering I started at 7:30.
I think you are right BigTex, I think this will be a way better setup than what I was using, I just hope it will idle ok until I can get to the dyno this week. I think it will be ok.
Old Jan 1, 2006 | 03:23 PM
mattrem's Avatar
Well after a scare yesterday, I am really pleased with the new cam so far. The power comes on at about 2000 rpm and is very smooth all the way up. I had thought I would see a loss of lowend with this cam,but there is none. I am very pleased with the idle also, a very faint lope. I have put almost 100 miles on it. I hope to maybe go to the dyno Friday morning, so Bryan can tune it and we can make some power. The XER lobe doesn't make as much noise as I thought too.
Old Jan 1, 2006 | 04:52 PM
Sport Side's Avatar
-At what RPM does it 'stop' pulling?
-Are you able to tell?
Thanks
Old Jan 1, 2006 | 05:43 PM
1SlowHoe's Avatar
Destroyer of Transmissions
What are the specs on the one you took out and put in?
Old Jan 1, 2006 | 10:37 PM
mattrem's Avatar
I went from a 216/220 525/532 on a 114LSA to a 220/224 581/581 on a 115LSA
Old Jan 1, 2006 | 10:39 PM
mattrem's Avatar
Thanks
I can't really tell, I will have to compare dyno sheets from last time and this time. I hope to have some answers on Friday.
Old Jan 1, 2006 | 11:05 PM
samdogmx's Avatar
8 Second Club
matt how was the idle & low end with the old cam, Im hoping its not too much differnt than my current one 206/216 .515/.525 112 lsa
